85 hp Mercury power trim swap
Art Burkett
Will the power trim from a mid to late 70's mercury 85 hp fit a 1970 85 hp
Chris1956
Honorary Supreme Mariner
Re: 85 hp Mercury power trim swap
As long as the PTT is the two trim cylinders mounted outside the transom bracket type, pump in the boat type, it will fit. Make sure you get the PTT brackets for the trim cylinders. They are essential.
