Lots of Throttle on land, barely any in water
Riknar
Weird situation here.
I have a 1969 Mercury 650 4cyl-2 stroke.
It starts easy, runs GREAT...
When I have it on land, with the hose and muffs on it, I get LOTS of throttle and RPMs
When I drop it into the lake, I get hardly anything.
It is NOT the motor position, as I have it in the same position on land and in the water. The only difference is the load on the prop in the water.
On land, I get what seems like a TON of throttle..but once in the water, it appears I have a lot less..can't get the RPMs up and I barely move.
Any ideas?
JB
Re: Lots of Throttle on land, barely any in water
That engine is NOT running great on land, Riknar. It has no load on it. It will do that fake act on 2 cylinders.
It could be running with one or two dead cylinders.
CharlieB
After you verify good spark on all cyl's.
Engines require a LOT more fuel under load in the water.
Chances are your carbs are dirty and need cleaning.
Be sure that your fuel pump is flowing good and all lines/filters and fittings are clean, clear, and tight.
