  #1
Old August 18th, 2008, 07:12 PM
pamcm1098 pamcm1098 is offline
Default Yamaha 90hp Alarm
I was running my 2004 90hp 2-stroke for about 45 minutes at 2000 rpm when the alarm started going off. I ran it for about another 2 minutes to get to a safe anchor spot. I let it cool for about 2 hours, started right up to run home, got up to 4000 rpm and it stalled completely. I had about half a reservoir of oil, and I don't think the engine was overheating (the water stream was coming out of the engine strong). The only problem that I might have is old/contaminated fuel. I've used the boat very little this year, and have only added 6 gallons to the 18 gallon tank since November (!). Would the alarm sound for water in the fuel? Any suggestions on where to start troubleshooting would be greatly appreciated. Thanks.
  #2
Old August 18th, 2008, 09:06 PM
triumphrick's Avatar
triumphrick triumphrick is offline
Default Re: Yamaha 90hp Alarm
First of all welcome to the forum!
The three cylinder Yammys have had an issue with overheating due to restricted water passages. Have you used the motor in salt water? There is a good bet that may be your problem.
Also, letting it sit or throttling back will let it cool enough to turn off the alarm. The alarm usually comes back when running it again at the higher rpm's.
Good luck!
__________________
KeyWest 2300 WA Twin Yamaha F 115's
  #3
Old August 19th, 2008, 12:31 AM
Yes, running exclusively in salt water, through floating eel grass at that time, but wouldn't the pi$$ stream indicator mean that the head is getting plenty of cooling water? There was also nothing covering the water intake screens. The engine gets flushed with the garden hose every time I use it as well. Would water in the fuel cause the alarm to sound? Thanks again.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Strange Alarm on 90hp Mariner ikemorton Mercury & Mariner Outboards 1 May 2nd, 2007 08:27 AM
1992 Force 90HP overheat alarm dcar00 Force & Chrysler Outboards 4 July 10th, 2006 12:03 AM
'95 Evinrude 90hp oil alarm Nitro_Brad Johnson & Evinrude Outboards 2 July 12th, 2005 11:15 AM
1998 Force 90HP Overheat Alarm Oldsaltydog Force & Chrysler Outboards 2 February 9th, 2004 08:17 AM
Temp alarm installation on 90HP Mercury dmixon Mercury & Mariner Outboards 6 July 24th, 2003 08:18 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
