is it running to hot
john fox
i have a 1998 150 efi,the water pump was put in in oct 2007,the water out of the pee hole is hot at idle so you cant keep your hand there for to long ,if i raise the throttle it then cools off should it be this way ? the overheat alarm does not go off
CharlieB
Re: is it running to hot
Hold a thermometer in the stream, you may be surprised at how hot 140 degree water feels.
john fox
is that the normal temp it should be. like i said as you raise the idle it does get cooler thank for your reply jf
tredragon
the higher the throttle, the faster you're pumping new water in. like a car's radiator cools better the faster you go (although different concepts)
kellyisu
Your impellar might be starting to go but still pumping enough water at idle for the thermostat to not trigger the alarm- just a thought
