  #1
Old August 15th, 2008, 08:48 PM
ddmcnair ddmcnair is offline
Default Need opinions on condition of aluminum hull
Folks,
I am about to start on the rebuild of a 1990 Starcraft Mariner 160.
Pictures of the boat are in the Photos section of this website in the
album "1990 Mariner."
The hull cleaned up pretty well other than some corrosion in the
stern. I filled her with water and it didn't leak a drop although
that's not always as good a test as putting her in the water.
I have attached three pictures
Empty Hull - gives you a sense of the "naked" hull.
Corrosion on Seam - how concerned should I be with this
corrosion/pitting along the seam? The corrosion is in the area of the
last two ribs on each side. I plan to coat the entire bottom (inside)
with epoxy. Anything else you would recommend?
Corrosion on Stern - There is significant pitting across most of the
stern and a hole about the size of a quarter well above the water
line. I plan to add an aluminum plate 40" x 11" on the outside of the
stern to add stiffness, put marine tex in the hole (sandwiched between
the new panel and the transom boards) and to put epoxy on the inside
of the stern. Any other suggestions? I will be mounting a 1996 75 hp
Mercury two stroke.
My most basic question is whether or not this level of corrosion would
make the boat a bad bet for restoration.
As an incidental question, any ideas on WOT for that engine and boat?
Thanks in advance for all your help.
Doug McNair
  #2
Old August 15th, 2008, 08:55 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: Need opinions on condition of aluminum hull
looks like a good candidate, instead of epoxy, use Gluvit on the interior, it is the aluminum boats best friend. what i did on one of mine to make seaming the deck easier, i ran 1x4's across like the one you have, 16 inches apart, screwing them to the stringers, then fastening the deck to the 1x4's. you are on the right track.http://forums.iboats.com/forumdisplay.php?f=407
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Aluminum hull barnical spots need help on how to remove-clean 86bonito Boat Restoration and Building 1 May 18th, 2008 01:19 PM
condition of 1983 WA hull blastoff man Boat Topics and Questions (not engine topics) 2 March 19th, 2008 12:30 PM
Need Opinions.....on hull prep drewpster Boat Restoration and Building 1 April 24th, 2007 09:49 AM
Need Opinions on a 14 ft. Sears V-Hull w/ a 15 HP Johnson cdaggett11 Boat Topics and Questions (not engine topics) 9 January 22nd, 2007 01:30 AM
Need advice: Paint suggestion for aluminum hull and deck mansueto Boat Topics and Questions (not engine topics) 0 April 12th, 2006 10:06 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
