I bought a replacement stator for 1980 merc.The new one has one more wire then original,it is black.I assume it is a ground,but where to hook it?THANKS
Not knowing which engine you have makes that difficult but in most cases it goes to the case mounting bolt on the switch box with the coil ground wires.
