Riverwilds
- Jul 10, 2008
- 1
Motor starts and runs fine for a few minutes, then stalls (can watch the fuel drain out of the fuel filter b4 it stalls). If you keep squeezing the bulb it will continue to run. If put in gear and revved it will run above idle with out stalling. Also stalls when it's in gear idling into dock after running out on the water, above idle, indefinitely. I am working on the idea that there is a vacuum leak, or the carbs have issues. There is some fuel seepage around the carbs, dripping off the bottom and coming out the throat after it stalls.
I have checked the tank vents, tried running it with a different fuel tank, rebuilt the fuel pump, replaced all the fuel hoses and vacuum hoses. Compression is good on all cyls.
Any ideas would be appreciated.
Thanks.
Thanks.
