Re: Mariner 8 prop shaft repair
My lower unit ran with basically no gear case oil. As a result the prop shaft is scored which I need to replace. Can you tell me about the connection between the reverse gear and the bearing carrier? I assume their should be no play between these parts. Mine does, so do I need to replace them also?
Reason: New title needed
