94 johnson 150 Ocean Runner
hookembig81
i took went fishing the other day and the motor was running fine...as i was going back to boat rap the motor died on me..i had a hard time starting it back up...i could smell gas real bad...i pinched the main fuel line then the motor started but didn't run long...i would try to start the motor again and it smelled of gas...when it starts back up it would blow out white and gray smoke...like it was flooded...it will only run for about 15 seconds then die...i need help...i think it could be the choke or the carbs could be dirty....any advice?
