  #1
Old July 12th, 2008, 12:05 PM
steve62 steve62 is offline
Send a message via Skype™ to steve62
Default 1977 Evinrude 55HP Ignition wiring
Could someone post a photo of the ignition switch wiring for a 77 55 hp evinrude please. I bought this engine and it runs great but the previous owner lost the keys and we had to pull the harness and by trial and error got it running. (it was still one the previous boat)I purchased a six terminal switch from our napa dealer.. Any help is appreciated.
Thanks in advance.
Regards,
Steve G.
__________________
If it ain't broke...fix it til it is!
  #2
Old July 12th, 2008, 12:36 PM
Joe Reeves's Avatar
Joe Reeves Joe Reeves is offline
Default Re: 1977 Evinrude 55HP Ignition wiring
What color are the wires?
  #3
Old July 12th, 2008, 01:31 PM
FillupD FillupD is offline
Key switch letter
S- 18G White to Neutral switch
C- goes to the choke 16G Purple/White #6 on Terminal Block
A- 16 G Purple # 4 on Terminal Block
M- 18G black to Ground Lead Remote Control (between A&B)
B- 16G Red/Purple to fuse
M- 18G Black/Yellow #5 on Power pack for kill switch I believe
Hope this helps
  #4
Old July 12th, 2008, 02:49 PM
The ignition switch has 6 pins. Magneto circuit, choke, ignition circuit, solenoid, ground and battery
The battery of course is red, ground is black and the choke is indeed purple/white. What color's are the ignition circuit, magneto circuit and solenoid?
the switch has the following letters associated with the wiring:
M - magneto
C - choke
I - ignition
S - solenoid
M- ground
B- battery
Thanks for the responses so far folks.
__________________
  #5
Old July 12th, 2008, 03:42 PM
If you look at the switch in the manual the letter go like this.
Top C to the left & A to the right side
Middle S & M
Bottom M & B
The B, bottom right, goes to the fuse, the fuse wire then goes to solenoid. There is also another wire on the solenoid that goes to terminal # 3. So off of the solenoid, one wire to terminal # 3 and the other wire to Switch B via a fuse. And a red 6G wire to going to battery+
It is red/purple going into the fuse and red going to the solenoid. Also red, from terminal #3 to solenoid.
The S white wire goes to the solenoid via the neutral safety switch to the smaller terminal on the battery side. The other small terminal is ground and of course the other terminal goes to the starter.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1977 Evinrude 55HP Truckie15 Johnson & Evinrude Outboards 4 July 10th, 2008 10:57 PM
1977 85hp evinrude power pilot ignition wiring alfred biever Johnson & Evinrude Outboards 2 April 30th, 2008 10:15 AM
1977 55hp Evinrude starter bigarr Johnson & Evinrude Outboards 2 June 30th, 2007 07:54 PM
Evinrude 1977 55hp - tacho wiring Qld_Kev Johnson & Evinrude Outboards 2 December 6th, 2004 01:14 PM
Evinrude 35 1977 - Ignition wiring - Help! newbboater Johnson & Evinrude Outboards 1 August 3rd, 2003 05:40 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
