  #1
Old June 27th, 2008, 12:53 PM
snakeyes146 snakeyes146 is offline
Default Dual Battery Installation Yamaha 100 o/b
I'm installing a second battery in a Playbuoy Marquis with a Yamaha 100 outboard and just wanted to know if the ignition circuit (at the switch) gets transfered to the "start" battery, or remains on the "house" battery. The installation of the "start" battery only has the lead to the starter attached and the battery charging lead from the isolator (all on the positive side)
  #2
Old June 28th, 2008, 08:52 PM
Big Keepers's Avatar
Big Keepers Big Keepers is offline
Send a message via AIM to Big Keepers
Default Re: Dual Battery Installation Yamaha 100 o/b
Isn't the ignition circuit a part of the main wiring harness from the controls to the motor? If so, and I hope it is, yeah you'll just run the positive lead from the start battery to the starter. You'll need some wire to connect the two batteries together on the negative terminals. I'd buy the Blue Sea add a battery package and use the auto charging relay to charge the house. It comes with the switch, the acr and the instructions to install. It is real easy. The relay is better than a battery isolator because there is no voltage loss in the relay. When it detects a charging current it closes and charges both batteries.
__________________
  #3
Old June 29th, 2008, 09:27 PM
Thank you very much for the earlier reply, I really appreciate it. I have the second battery installed and have run a separate ground lead to the engine, adjacent to the other ground lead from the original battery. I like the install idea that you mentioned, however, the guy who owns the boat has already purchased the materials, including a solid state battery isolator, that he wants installed and has hired me to complete the job. So here is where I'm at: I have reterminated the alternator lead to the isolator and have made the appropriate connections from the isolator to the positive terminals on the batteries. Now, on the "start" battery, I have only one positive lead running to the starter, however the solenoid control is still on the "house" battery circuit. My question is whether or not that particular wiring at the ignition switch has to be relocated to draw power from the "start" battery, or is it going to be ok to leave it on the "house" battery circuit. What is considered the "normal" install technique?? It doesn't seem wise to have seperate power source for starting, when the control is from the source that could potentially be drained??
  #4
Old July 13th, 2008, 02:17 PM
If I understand you correctly I'd say leave the solenoid hooked up the way it is. As long as the positive from the starting battery is what the starter motor is drawing off it shouldn't matter how you send 12 volts to the solenoid. All you do when you turn the key is send 12 volts to the solenoid to trigger it to close. When it closes it makes the connection between the heavy wire from the starting battery to the heavy lead between solenoid and starter motor. Normally the small 14 gauge wire that powers the solenoid comes from somewhere in the engine's wiring harness.
Because he is using an isolator make him aware that there will be a voltage loss by the time the charging current gets to the batteries from the alternator. He needs to keep an eye on both batteries to make sure they get charged enough. If he starts to have batteries drain down then they aren't being charged sufficiently by the alternator. If he trailers the boat then it is easy enough to just hook up a battery tender to the batteries. If he is on a mooring or docked where there is no shore power for an onboard charger he could have issues. Something for him to be aware of.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1966 100 HP shift cable installation RJW Johnson & Evinrude Outboards 16 March 4th, 2007 07:44 PM
dual battery installation mborup83616 Electrics, Electronics and Trolling Motors 1 May 31st, 2006 01:38 PM
Dual Battery Setup izuizme Boat Topics and Questions (not engine topics) 6 August 22nd, 2003 01:57 PM
Dual fuel tank installation Cyrus Boat Topics and Questions (not engine topics) 2 July 29th, 2003 10:05 AM
? about dual battery switch blipship Boat Topics and Questions (not engine topics) 2 April 23rd, 2003 04:40 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
