zanezwerenz
Thread starter- Joined
- May 22, 2008
- 8
I have read through all the posts and have not quite found the answer to my issue. Sure hope someone might be able to provide some suggestion to fix my problem.
I have a 2003 4.3L Mercruiser I/O and my tachometer is stuck and sitting at 2000+- rpms. My needle will NOT go to zero when I turn the key to the on position and it stays there regardless of engine RPM's. I have taken the boat out on the lake and it runs perfect. No miss firing or problems starting. Tach worked perfectly before it was winterized last Fall.
Any help would be appreciated.
Thanks
Zane
Thanks
Zane
