  #1
Old June 5th, 2008, 03:46 PM
Old No 7 Old No 7 is offline
Default best way to pull wires in a center console?
I have an 18' angler center console that I'm trying to install a fish finder in. there is one PVC tube for the wires in the boat and it's fairly packed. Using a fish tape, i can get the wires to about 10" from the end of the tube and no matter what i do it gets stuck. i used duct tape on the end to cover the tape loop, and make a tapered approach to the connector. i also coated it with dish soap, no good. i've also tried to move the cables/wires i have access to from under the console, no luck there either
Is there a better way to do this? Any Tips? I asked the local dealers tech, and he jusy smiled and said "welcome to my world"...
that tube is the only straight shot to gat a fish tape through. I have tomorrow off and i'm determined to get this done, but i'd rather be using the boat instead of working on it all day if possible.
thanks!
Mike
  #2
Old June 5th, 2008, 04:17 PM
Zero Balance's Avatar
Zero Balance Zero Balance is offline
Default Re: best way to pull wires in a center console?
I had a similar problem once and used a piece of cable (garrage door type) to chase my wiring. It was thin enough to slide through the conduit and stiff enough to get all the way through. I just kept twisting it as I pushed it through. and had my wiring taped to the end to complete the run. You may need to burn the end of the cable slightly to keep it from fraying. A little electricitions lube goes a long way...
  #3
Old June 5th, 2008, 05:06 PM
H2ot Times H2ot Times is offline
If all else fails use one of the existing wires to pull in your new wires and a replacement for the one you pulled with. Not my first choice but hey.
  #4
Old June 5th, 2008, 05:47 PM
fishmen111's Avatar
fishmen111 fishmen111 is offline
Cut the end off of your fish and round it. Have you tried going both ways? How wide is your fish? As previously mentioned, you may need to cut a good strong existing wire to do your initial pull. If you do that, of course remember to include an actual pull line for the return. My last one took me 2 hours to pull.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
New Boat: Center Console , Walkaround, or Dual Console PAkev Boat Topics and Questions (not engine topics) 17 April 2nd, 2006 08:14 AM
Best way to tow skier behind Center console w/outboard? dsiedt Boat Topics and Questions (not engine topics) 7 November 20th, 2005 06:05 PM
Best center console ever built? BLU LUNCH Boat Topics and Questions (not engine topics) 8 June 14th, 2005 01:38 PM
Center Console - What is the best Ply? Knightgang Boat Restoration and Building 8 November 12th, 2003 06:18 PM
installing wires for transducer on center console lonewolf5347 Boat Topics and Questions (not engine topics) 1 May 31st, 2003 07:29 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
