Re: 1996 Evinrude Ocean Pro V4 Loop Charged 115HP Fuel/Oil Pump?
Upon a closer look, the oil seems to be coming somewhere around the outlet (inlet?) on the fuel pump that has a hose connected to it which the parts manual calls "HOSE, Vapor sep. to pump assy." The other hose is the oil supply line and it seems dry around where it connects to the pump.
Does anyone know if that hose is under pressure and could be spraying oil above it? I'm finding traces of oil just above the hose connection (the "HOSE, Vapor sep. to pump assy." hose) , so, unless there's enough pressure on the line to force some oil upward, it would seem like it's leaking from the pump and seeping down onto that hose connection.
I'm going to reseat the hose and clamp as Jim suggested, clean up all the oil and keep an eye on it.
Has anyone done a fuel pump replacement on this motor? It doesn't look like it would be too hard of a job.
Thanks,
George
