FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
i had the water pump done last yr , and it was fine now i started her up yesturday and its driping out. can i blow it out could there be bugs in there or is it the thermistats ? thanks
Probably clogged with crud from sitting. Try getting a piece of wire and running it up the tell tale. Maybe that will work. More experience people will reply here soon.
Probably just a clogged hose.Pull the hose off the tell tale and see if it sprays water out of the fitting of the exhaust cover.If so the hose is plugged.
Bugs love that little opening for some reason..
There should be water coming out if the T-stats are open or closed.
