OMC out board hell
loydpatrick
Ok i have a 74 fiber form IO 165 hp omc stringer out drive. So here is the hell, I took a log at 25 mph and it tore my whole out drive off. Broke the upper gear casing at the pivot bearing (where the out drive hooks to the boat). So I went to the marine wreckers and found a new case but they wanted 450 for the case and 700 for the whole unit with gears. So me being the cheap skate I am I went to ebay and found a case. It measures the same in all regards but there are differences that I did not notice before I bought it. First it has a small gear that stears the OD and mine dose not have that and the new one did not come with a water pump I fiqured that I could just transfer the old one. Well of course the old one dose not fit and the water pump input shaft for the old one is a 12 spline while the new one is only a 4. So after finally finding the part number on both units I find that my old one is a 165 hp and the new one from ebay is only a 90 hp. But the cases are identical, so my question is can I use the one I got from ebay, is there a way to make them fit?
mbroome
Re: OMC out board hell
look for the model number on your outdrive as well as the model number on the motor. Your best bet and least frustrating is a remanufactured drive, not a junk case from ebay..............you are looking at around 4 grand for a quality rebuilt stringer 800 outdrive.......
GiMLit
loydpatrick
Where abouts are you located?
loydpatrick
Lodi California, and thats the thing I bought the boat for 800 so its only worth a junky ebay upper gear case but thanks
firehog6305
Did you try Rancho marine Recycle, or shipwreck marine in Rancho Cordova, I'm in the foothills above ya, and they have always treated me fair, and stood behind their parts
mbroome
heres an alternative:
ebay item # 170206912587
I placed the first bid, feel free to out bid me! Let me know if you bid and I'll stop. I'd only want it so I have a spare in the shed, I think you need it more!
-Matt
bruceb58
Honorary Supreme Mariner
If his OMC is a 74 vintage, that ebay drive won't work.
