Re: I screwed up... help!!
Hay SGTMaj how warm is it there??? you just might need some heat , john
It's pretty cold outside, but the boat is in the garage with a heater... should be maybe 50 overnight, and around 65 in the day. I'll try adding a second heater
I hope you're not using automotive Bondo below the waterline. Bondo will absorb water.
No, not below the water line, or even anywhere where water would normally be. Just fixing some minor cosmetic things that were bugging me that I couldn't sand out.
Ive done that before. It will eventually harden if you used at least some hardner. The less hardner you used the longer it will take but it will eventually get there. It took almost 2 days one time for me cause i was doing the same thing and trying to get some more working time. I had to wait for those 2 days to continue working on that section. I was able to finish it up but it just took a long time like i said.
That's good to know. It's starting to set up now. Just for the sake of trying it, I smeared some hardener over the top of one area that was probably the worst last night, and it's almost completely set up now, and not just with a top crust like I had expected. Most of the rest of the areas are starting to set up also, but there is one other bad spot I'll try smearing some hardener over the top of it too.
Thanks everyone.
