Yamaha Gear case reassembly
Thumbtack
yamaha L200, 2001. To help identify, the prop shaft has a ring that the bearing carrier goes against then on the other side of the ring is the fwd gear and its bearings.
I pulled out the bearing carrier but left the fwd gear and its bearings on the prop shaft. the book shows how to put everything back together with the FWD gear and its bearings removed from the propshaft but i didn't need to remove them so i left them on.
Can i reinstall the bearing carrier onto the prop shaft without removing the fwd gear by pressing down on the thrust washer, or do i have to take off the fwd gear and unpress everything?
