Re: HPDI Yamaha Problems
rather than have a breakdown simply learn how the 3.3L Z motors work.
you have been chasing a non problem as in N that engine idles on 4 cylinders by desighn, above about 1500 in N it runs on 2 cylinders,by desighn.
high idle can be caused by a code set,TPS set incorrectly or a throttle shutter not properly adjusted.
just because an injector code is set does NOT mean an injector had an issue.
low high pressure fuel can do it as well.
your either going to have to take a crash course in HPDI systems,yamaha isnt the only manufacturer to try it, EFI systems as some of it overlaps and a couse on electronics diagnostics.
either that or you will find poke n hope is expensive.
test the operation of the nuetral switch on the shift slide.
thats why in gear it runs on 6 and out of gear it runs on 4.
the oil pump was an update. ECU failure I have not seen on that engine but it could happen.
