mikey.himself
- Sep 11, 2007
- 130
My 5.7L Mercruiser in my rinker 28' with the alpha one drive is bucking when in the rpm ranges 2800-3200. Im pretty sure its engine only related. It inconsistantly at random bucks if your in this range, it also only lasts for half a second. It sounds like a cough, for real. Engine will achieve WOT without any problems (GM Scream). In any other range its fine. Does the carb need some attention? Is it starving for fuel for that one spot? is it running lean? is the distributor or wires in need of a change?
Sound of it:
MMMMMMMMMMMMMMMMMMMMMMMM-CHFF-MMMMMMMMMMMMMMMMMMMMMMMMM-CHFF-MMMMMMMMMMMM.....
Sound of it:
