I am getting intermitting ignition on a 1987 mercruiser/sea ray.(thunderbolt ignition)I have tested the coil and am getting a good read off of a test light.Although i am getting a hot light on both sides of the coil.I also tried swapping out the coil w/ a msd coil with no help.I also tried putting on a froiedns ignitiom module(box on the side of the manifold)also with no help.Only other thing i can think to do is maybe put on a ohm distributor and bypass it all?When it did start it ran very rough and would just choke it self out.Any help would be greatly appreciated!!
