After giving up on obtaining a used lower unit I have undertaken the disassembly of the damaged one. I have gotten to the point where the driveshaft and pinion must come out to remove the gear and shift mechanism. The unit set dry for some time due to the case freezing and cracking. All shafts and gears so far are smooth and crisp but bearings/seals are shot. I have removed the four bolts and the top bearing plate on the driveshaft and can turn it a little and it moves up and down about 1/4", but will not pull out. The information I have shows a set screw, but the one I have removed doesn't seem to help. It was in the water intake area. <br /><br />What do I do to remove the driveshaft? The shift mechanism is also stuck won't move up or down. The prop shaft will turn and the pinion is not engaged.<br />Thanks
