  #1
Old November 17th, 2007, 05:37 PM
ScttAppleby ScttAppleby is offline
Default Evinrude Shifting Problems
Just took my new old 1974 Evinrude 40hp out for a test spin. When I went to load it on the trailer, I had to put it in reverse. Then when i moved the shifter into forward it stayed in reverse. Worked it back and forth a few times and it came out of it and back into forward. Is there a way to adjust the travel or something so it shifts correctly.
  #2
Old November 17th, 2007, 06:26 PM
F_R F_R is offline
Default Re: Evinrude Shifting Problems
Sounds like one of the ends is loose on the remote control shift cable. If anything else ahd come loose it wouldn't reattach itself. Just for kicks, check the oil in the lower unit.
  #3
Old November 17th, 2007, 06:28 PM
F_R F_R is offline
Well, yes come to think if it, check the screws that hold the shift lever to the shift shaft on the motor.
  #4
Old November 17th, 2007, 07:03 PM
I took the shifting cable off so I could shift it at the side of the motor. It now is stuck in forward you can move it to both extremes and it stays in forward, but there is no grinding. The rod inside the cowling is still in tack and not slipping there.
  #5
Old November 17th, 2007, 07:30 PM
F_R F_R is offline
By rod inside the cowling, do you mean behind the oval disconnect cover on the side about half way down? Anyhow that is the next place to look. If the rod is not going up and down when shifted, it has come loose under the powerhead. But if it is going up and down but not doing anything, you must have bad news in the lower unit.
  #6
Old November 17th, 2007, 07:46 PM
When it does shift that rod goes up and down, but when you try to shift it and it doesnt shift the rod doesnt move. you can apply pressure but it doesnt move, but the shift handle does go back and forth.
  #7
Old November 17th, 2007, 08:34 PM
F_R F_R is offline
IF the shift lever is tight on the shaft, and IF it is going back and forth without the rod going up and down, then something is wrong or broken under the powerhead. I've seen it happen (broken clevis) many times. But usually when it's broken, it's broken. No self-healing. Don't know what else to tell you except pull the powerhead and take a looksee.
  #8
Old November 19th, 2007, 01:20 PM
Went out and messed with the motor again. The shift lever will move, and in turn move the rod up and down in the view hole but the prop does not change rotation. Occasionally the shift lever will stiffen up and not want to shift forward and backward though. Shot some wd40 down the view hole didn't seem to make a difference. Got any ideas?
  #9
Old November 19th, 2007, 01:27 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
keep your post together, that way we have history.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #10
Old November 19th, 2007, 08:33 PM
I apologize i'm new to how this all works. Hopefully can figure it all out, and figure my shifting issue out also.
  #11
Old November 19th, 2007, 08:54 PM
F_R F_R is offline
The whole key to diagnosis is that shift rod. Your trouble has to be either upstairs or downstairs. You don't seem to be grasping the idea. And I can't be there to check it for you.
If the shift rod moves up and down and it doesn't shift the gears, there is trouble in the lower unit. WD won't help a bit.
If there is any slack in between when the shift lever moves and the rod moves, it is broken under the powerhead. When one moves, the other must move. BTW, when the clevis breaks it does tend to make it difficult to move the shift lever....sometimes. Hate to make this more confusing, but those motors also corrode the upper half of the shift rod till it breaks in two. Just before that happens, it bends back and forth. But it's still a under-the-powerhead situation.
  #12
Old November 26th, 2007, 02:53 PM
I decided to drop my lower unit. I have unbolted it and it dropped down an inch or so, now it appears to be stuck. It will not come all the way off got any hints???
  #13
Old November 26th, 2007, 03:58 PM
kjdunne kjdunne is offline
Have you disconnected the shift rod at the top? Look under the carbs where they are attached to the engine and there is a bolt that connects the shift rod to the linkage that the remote control lever moves. You probably need to remove the starter motor to get to it, and use an extension and U-joint to get a socket on it.
  #14
Old November 26th, 2007, 04:01 PM
P.S.- putting the shift lever in the reverse position makes the bolt easier to access.
  #15
Old November 26th, 2007, 05:38 PM
The shift lever on the side of the motor will shift now from F to N to R. The rod in the view hole on the side of the motor will also go up and down, so that leads me to believe the problem is in the lower unit. So I tried to take the lower unit off I removed the seven bolts the unit dropped an inch or two then seemed to bind for some reason. Got the tips from the previous post but my carb is on the front of the engine and there are no bolts under it. I tried to loosen the bolts on the shift rod in the view hole still seemed to make no difference. I'm at a loss and need help. Thanks
  #16
Old November 26th, 2007, 05:40 PM
HighTrim's Avatar
HighTrim HighTrim is offline
If its dropping an inch, then stopping, then it is still attached to the shift rod probably. You cant just loosen them , you must remove them. It may also be binding a bit.
__________________
Chris
  #17
Old November 26th, 2007, 05:43 PM
So I should loosen them untill they come off? Is it nessessary to mark the rods where the clamps were postioned?
  #18
Old November 26th, 2007, 05:50 PM
HighTrim's Avatar
You may be able to leave in the last couple threads. What you are removing is number 49 from 54.
__________________
Chris
  #19
Old November 26th, 2007, 05:51 PM
guy74's Avatar
guy74 guy74 is offline
Send a message via Yahoo to guy74
You just take the bottom one out.
__________________
1973 Glastron V 156
1989 Evinrude 85XP
  #20
Old November 26th, 2007, 05:59 PM
HighTrim's Avatar
You can see it better here.
"http://www.crowleymarine.com/brp_parts/diagrams/30862.cfm"
__________________
Chris
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
'66 Evinrude Sportwin 9.5 HP shifting problems froggers&whales Johnson & Evinrude Outboards 7 June 14th, 2005 10:57 PM
88 Evinrude 175 shifting problems schlosss Johnson & Evinrude Outboards 1 May 16th, 2005 07:49 PM
'81 Evinrude 35HP shifting problems sumrskyjam Johnson & Evinrude Outboards 3 June 20th, 2004 06:32 AM
Shifting problems-85HP Evinrude campjung Johnson & Evinrude Outboards 2 July 27th, 2002 08:34 AM
1973 Evinrude 70 shifting and steering problems stikman63 Johnson & Evinrude Outboards 0 July 7th, 2002 11:52 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
