Good morning
I guess let me start from the beginning. I was going fishing about a two months ago
And went to test run the motor the night before and found out the power pack went
Out (No spark) after sitting up for a couple of weeks. I had no problems prior to this
Except the tach would act a little funny every now and then. So I changed the power
Pack and everything was fine the first trip. The next time I took the boat out it ran
Fine the first 20-30 minutes and then the motor would shutdown and come right
Back on like someone was turning the key on and off. I would back down on the
Throttle and it would run fine for a little while and start doing it again. I usually run
The boat about 5200 RPMs and have about 20 pounds water pressure at that RPM.
Next I talked to a boat mechanic buddy of mine and he said he would try changing
The stator and regulator so I did that and now the motor won?t Idle. It starts up fine
And then after 3-4 seconds just shuts off like someone turned the key off. If I start
The motor and idle it up to about 1200 RPMs it will stay running until I drop it back
Down to an Idle. Maybe got a bad Stator? Any Suggestions?
