Motor Problem
shipwreck
Evinrude 1967 Alternator
My Evinrude 1967 Alternator Is Show That Grounded IT IS On One Of The Two Yellow Wires OTHER NO READING AND BOTH WIRES NO READING.
I Just Read A Article By Joe Reeves , About The Diodes KillING Tachs IF THEY ARE BAD.
The Diode Tested Good , I Want To Install Tach From The Neg And The Coil.
Will The Grounded Alternator Effect My Tach (kill It) ? Or Should I Be Ok?
Also , How Dose The Alternator Ground Out Like That, I Thought They Are All Sealed Up Not Exposed To Metal Of Powerhead To Ground Out?
Edit/Delete Message
CAN ALTERNATOR BE REBUILT?
