help please
waterdawg69
can someone tell me how to purge air out of my tilt/trim cylinders. i belive i have air in them.
180shabah
Re: help please
Whose trim cyls do you have???
Mercs are self purging, trim in, trim out, repeat....
waterdawg69
Re: help please
so all i have to do is open vent screw a move the outrive up/down, ohh its a merc
waterdawg69
Re: help please
no its always closed. when is it suposed to be open? all the way out or half way? i think the reason it don't go all the way down is because there is air in it. thanks for the quick replies
Haut Medoc
Re: help please
Then remove the vent screw & cycle the unit up & down while monitoring the fluid level......:)
Don S
Re: help please
What is your actual problem, other than you believe you have air in it?
What year Merc is it?
waterdawg69
Re: help please
well don its my tilt/trim it goes up great, but going down it starts going down geat untill it gets half wasy down it stops but motor and everying still runs, i greased everything, fluid is full. im just stuck on this one.
Don S
Re: help please
Bet there is a lot of corrosion around the rods where they go into the trim cylinder, that or the pump is on it's way out on trim pump. Leaky down circuit.
waterdawg69
Re: help please
the rods are really shiny clean, is there any other way to tell if the pump is going bad? that i could try. and is power steering fluid the same as tilt/trim fluid.just wondering. thanks alot don
