  #1
Old August 16th, 2007, 02:37 AM
catfish hunter's Avatar
catfish hunter catfish hunter is offline
Default Evinrude 25hp motor running like crap!
I just got a boat that has been sitting for about a year. Has a 1981 Evinrude 25hp motor on it with electric start. It will start up fine however while running it acts like its misfiring and jumps all over the place. In mid rpms it runs great but in idle and at high speed it misses bad. I have cleaned the carb, checked the compression (110 in both cylinders), changed the spark plugs and seems to have good spark. I think it maybe the timing however I have no idea how to check it on this motor. I noticed the rubber stop on the starter is all the way in and the lock screw on the throttle rod is just hanging there. I didn't know if this might be to blame as well. Any help would be appreciated.
Thanks
  #2
Old August 16th, 2007, 06:50 AM
bgbass.1 bgbass.1 is offline
Default Re: Evinrude 25hp motor running like crap!
that timing screw should not be tuned all the way in your timing is advanced all the way.get a seloc manual it will telll you how to time it.I know you have to be at full throttle under load DO NOT USE MUFFS.the manual will also show how to syncronize your linkage.good luck
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1975 25hp Evinrude won't stay running. cajun66 Johnson & Evinrude Outboards 9 June 9th, 2007 07:58 AM
'83/84 25hp Evinrude won't stay running daveho Johnson & Evinrude Outboards 1 May 29th, 2005 07:43 AM
25hp evinrude kicks when running jamesboater Johnson & Evinrude Outboards 3 April 24th, 2005 05:38 AM
1988 Evinrude 25hp-won't start after running Goose Hunter Johnson & Evinrude Outboards 5 February 22nd, 2004 02:15 PM
77 25hp evinrude running hot tdr9499 Johnson & Evinrude Outboards 5 February 1st, 2004 11:11 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
