jbjennings
- Jul 18, 2007
- 3,903
I am in dire need of a real mercury expert. I have a 1972 Merc 9.8. I have gone through the whole lower unit and water pump, replaced impeller, blew all tubes out, took water jacket cover plate off and looked for debris, looked at water pump housing (it looked fine, no grooves or anything). It pumps o.k. at dead slow idle but idling up at all it shows less water coming out the telltale and at fast idle the flow is kind of an intermittent or pulsating one that seems like it's constricted. I took out the flush screw and it pumped more water out at dead slow idle than at fast idle. Going down the lake wide open the water coming out of the telltale is insufficient and hot, not warm, but hot. After a 10 minute ride at wide open, the cylinders were pretty darned hot--not overheated but enough that I'm certain if I ran it a long time I would probably burn it up. I am baffled by this and don't know what else to check. I blew a lot of air through the power head and just don't believe there is any obstructionin any of the passages. I also don't understand the good flow on idle and less flow but a harder flow on faster throttle. The power head runs and looks great and the cylinders and pistons and stuff looked as clean as a new motor (absolutely no carbon build up), just as good as the outside of the block which looks brand new also. It appears to be a very low hours engine. I'm sure this baffling problem along with the water in the gear oil is why the original owner sold me this motor! My dad said years ago he had a 20hp merc with a similar cooling (problem and it turned out to be the lower unit housing even though the dealer mechanic (a good dealer mechanic) couldn't even see anything wrong with the old housing. Any ideas? I hate to be so lengthy but this is my first post on the forum and I wanted to be specific in my description of the problem. The lower unit also leaks water into the gear oil although I replaced the prop shaft seal and o rings on the bearing carrier. Please help---- jbjennings:
