  #1
Old July 31st, 2007, 12:50 AM
lowercase_j lowercase_j is offline
Default mercury 200 efi will not start
I have a 1998 200 efi on my ranger bass boat, I have only hade this boat for about three months. Went to take off the other day after getting in the water and it would not start. Ran my battery down, so I jumped from one of my trolling batteries. When I made the last connection there was a pretty good arc, then nothing. Still would not start, so I let it set for a while, I tried four or five times and never did get it to start. Never hade problems till now. I got home and plugged my chargers up and just out of curiosity I tried to start my motor again. The darn thing fired up with no problems, time after time. Could someone help me figure out what the heck is going on here?
  #2
Old July 31st, 2007, 10:07 AM
jimc_LA jimc_LA is offline
Default Re: mercury 200 efi will not start
lowercase, Without more information troubleshooting your situation is difficult. I have a 2000 V6 200 EFI. One thing that happened to me once was that I had left the live well pump on overnight at the camp w/o plugging into the charger. Drained the battery down dead as a doornail (and I lost most of my live bait). I jumped it and the motor would spin fine, but would not start. Tried all sorts of things until I read in the user manual that unless your battery has at least 12.5 volts, the high pressure electric fuel pump (located inside the VST) will not operate and the engine will not start. I let the battery charge for about an hour and she fired right up as if nothing had happened.
It could be that your cranking battery was so dead that it was sucking the life out of the jumping battery while jumping. This has also happened to me. In my case, I ended up having to disconnect the dead battery and hook the fresh one up directly to the cables. Apparently the dead battery drains just enough voltage to have the net voltage drop below 12.5 volts. It can be frustrating because the engine seems to spin fine while trying to start, but it won't fire.
Once you got home and re-charged the main battery - problem solved.
Just my 2-cents. I have had this same experience and it was only through reading the user guide that I came across the required 12.5 volts for the fuel pump to operate.
Hope this helps.
Jim C
  #3
Old July 31st, 2007, 08:55 PM
thanks a lot, thats sounds like a likely explenation.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
95 Mercury 150 will not start bassfishinggal Mercury & Mariner Outboards 3 October 4th, 2004 10:20 AM
Problem, Mercury 500, start at home, wonÂ’t start at lake Nandy Mercury & Mariner Outboards 13 May 22nd, 2004 12:53 AM
Mercury 5000, start at home, wonÂ’t start at lake. Nandy Mercury & Mariner Outboards 18 April 17th, 2004 01:02 AM
70 hp Mercury won't start farmtruck56 Mercury & Mariner Outboards 9 July 18th, 2003 04:07 PM
50 Mercury Start but hard to stay start. mann Mercury & Mariner Outboards 1 July 26th, 2002 02:26 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
