  #1
Old July 29th, 2007, 11:45 PM
mdbauer62 mdbauer62 is offline
Default 1983 Evinrude 115 hp leaking water under cylinder
I have a 1983 Evinrude 115 hp outboard on a 17' ski boat. While at cruising speed, I noticed water coming out the opening where the control cables go into the engine cover. When I removed the cover, I noticed a weak stream of water leaking from under the lower cylinder on the port side of the motor. You could not see the exact leak, it was approx the bottom of the cylinder. The water was hot. I pulled the spark plug on that cylinder, and it was the same color as the other three, so I don't think the cylinder is sucking water into the combustion chambers? Any ideas? Could it be a gasket, or a crack in the water jacket?
  #2
Old July 30th, 2007, 07:28 AM
reload reload is offline
Default Re: 1983 Evinrude 115 hp leaking water under cylinder
Could be water jacket gasket
  #3
Old July 30th, 2007, 09:22 AM
Thank you for your reply. Would this be a head gasket, or a cylinder sleeve gasket? I see that there is a gasket for the head area surrounding the plug, and then a gasket for the cylinder head. I am going to run it in the driveway tonite with the water ears, and use a dental mirror to see if I see the leak better.
  #4
Old July 30th, 2007, 10:48 AM
Dennisanoka Dennisanoka is offline
The water jacket is on the outside of the head. You do not need to remove the the head to remove the water jacket cover or the gasket. You can see the exploded view here: http://www.evinrude.com/en-US/Access...e.Diagrams.htm
  #5
Old July 30th, 2007, 11:29 AM
Thank you for your help! I looked at the diagram, and it looks like item 30 is the cylinder head cover, and item 29 is the gasket. Hopefully it is just this gasket. I live in Michigan where it get below freezing in winter. Has anyone seen a head or block crack in this area? Can anone tell me the torque specs for the cover bolts? Should I use gasket sealer? I often used the spray one "gold" sealer that is recommended for head gaskets. Is this appropriate for an outboard?
  #6
Old July 30th, 2007, 03:31 PM
If you live in the UP that would make you a "U"per. And it does indeed get very cold there. If you live in lower Michigan, well it's cold but not THAT cold. I am over here in Minnesota which is the ice box of the nation. Back to your question, I have not heard of water cracking any heads. I have heard of water freezing and cracking a lower unit, that's why I refill mine in the fall. But I do not believe there would be enough water left in the engine to crack the head. I also raise and lower mine 2-3x to get it to all drain out. I did not use any additional sealer when I replaced mine. Regarding the torque specs, they are not much so you'll either need to look it up in the manual or wait for someone else to post it. I do not have the manual right now. My guess is 7-8 ft. lbs.
  #7
Old July 30th, 2007, 03:36 PM
iwombat's Avatar
iwombat iwombat is offline
If you leave your motor in the tilt position it won't drain properly and could very well hold enough water to freeze. Never seen it happen, but it's possible.
Begging your pardon, Dennis, but I think Alaska holds the title of the icebox of the nation.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1983 40hp Merc -water jacket leaking by upper plug davebad22 Mercury & Mariner Outboards 2 September 12th, 2006 06:23 AM
No spark #1 Cylinder 1983 75HP Evinrude 71whaler Johnson & Evinrude Outboards 11 August 9th, 2005 01:44 PM
Cylinder of 175 RX2 leaking Water relowrie Mercury & Mariner Outboards 4 September 21st, 2004 09:23 AM
cylinder head leaking water markdavid Mercury & Mariner Outboards 4 August 30th, 2004 07:27 PM
Early 70's 7.5 leaking water from top cylinder Ryche Mercury & Mariner Outboards 6 July 30th, 2003 02:37 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
