Re: Fly Wheel removal
Get a better puller. One made of steel. A decent one won't break. Also make sure you have Grade-8 pulling bolts. They won't break either. Then don't be timid. Give it heck and it WILL come off with a pop. No heat, WD, or any magic potions necessary. As far as (gently) prying the flywell upward and giving the center puller bolt a whack when you get it as tight as possible, that is a common old practice from way back....but now BRP says don't do it. Whatever.
