Re: Seam on Centerline?
I agree that the tortional stability of the hull is a very important factor and that the most stability will be gained by running the sheets across longitudinal stringers. The other important consideration is that the floor will be spongy feeling between the stringers if not run crosswise. Plywood is more rigid in one direction than the other. Almost always made with an odd # of plies. I would assume that the 5/8 you are dealing with is 7 ply. The Facing veneers run longwise on the sheet. Grain direction alternates with each ply. If 7 ply is used, 4 plies run longwise and only 3 crosswise. Even if you couldnt remove one of the side bolsters, I think you would be better off with 4, 2x4 pieces than one 4x 8 piece. Remove the bolster. One thing I can tell you from long ago personal experience with this same project: Be VERY aware of where the hull is relative to the floor when cutting the old floor out. If you are working on a 1958 Dorsett Eldorado, the floor practically touches the outer hull at the sides. Set the saw blade only deep enough to cut through the floor and dont cut all the way down both sides, before checking to see that you are not too deep.
