Barnacle_Bill
- Feb 8, 2004
- 6,469
I did a link & sync with no problem except figuring out where to make the final idle speed adjustment. Usually its pretty obvious but I'm drawing a blank on this one. I can id the full throttle stop screw, Idle timing screw, WOT timing screw and throttle cam adjustment screw. Where in the world do you make the final idle adjustment? Manual is absolutely no help.
