Quote:
Originally Posted by Laddies
With the carb top off the carb turn it upside down the lower float lever (which normal rides on the float spring but when upside down is now on the top) should be dead level or even with the other pin. The spring on the top of the float should stick out of the float 3/32"
i've adjusted the float and seat vavle and it still over loads with fuel .
float moves up and down fine .
is there a fuel adjutment screw that will cut the fuel down
