I'm running a 25 hp 1972 Johnson on a 14' semi v haul. The engine seems a little heavy for the boat, but it runs great. However, this past weekend, I could only run at about 1/3 - 1/2 throttle. If I opened it up, the engine would sound like it came out of gear or peel out, but of course it didn't. I've read some other threads about a prop hub slipping problem, which sounds like it could be it. I'm not sure the age of the prop, but it looks to be the original. There was no out of the ordinary jerking or grinding that I could notice. I drained the oil and it looks fine. Does this engine have a prop that could slip? I took it off and I can't see any rubber hub. If it is, any help on a source for a new one would be appreciated
