Re: Where exactly is the waterpump?
On a Bravo the raw water pump (or sea water pump) is located on engine STARBOARD (vessel RIGHT) and is belt driven. On some models the sea water pump drive housing has the fuel pump mounted on it as well.
If you have a failed pump that has broken vanes, you need to find all of the pieces or you could have blockage downstream of the pump.
On my 97 model year 7.4L GM engine, the oil cooler is downstream of the pump and it will stop all the impeller pieces. If you have a lot of pieces broken off it could seriously block the flow of coolant possibly causing an overheat condition at high power settings.
I recently replaced the pump and housing... I got the new one
HERE
The impeller was still intact but was clearly damaged from running dry, and the housing was looking a little cooked. I also found the remnants of a previous failure crammed up into the oil cooler. All the broken impeller vanes fell out when I removed the hose from the oil cooler....so be sure to check for that!
If in doubt, just replace the whole pump/housing.
Regards,
Rick
