question ?, is it possible to weld a crack on the lower unit of a 1973 135 hp ? the crack is on both sides, rite about inline with the shaft that goes into the bottom of the motor where the water in intake is the right side of the motor it starts below a "pee" hole and goes all the way to the skeg plate and is small and smooth the other side is 2.5 inches long but has a lip protruding a little. i am wrong in thinking it is trash or should i give it a try.. thanks as always mike
