I have purchased a used lower unit for my 125.The seller says it has been tested to operate in good order.The unit is yet to be installed on the motor.
My question is this:How much force should it take to get this unit in and out of gear? Should I be able to spin the shafts and get this unit into gear by hand? Currently the shift shaft wont move up or down by hand and I just cant remember if it should or not.Do I need to be hooked up to the shift lever to get it in gear or should it shift easily by hand ? Im almost ready to install this unit but want more input on this matter before I proceed.
Thanks for your help and thoughts,
Sp0iler
Sp0iler
