  #1
Old May 28th, 2007, 06:14 PM
barroomhero barroomhero is offline
Default 25 Mariner Carb issue
Hey, I'm working on a 1998 Mariner 25 hp. It had a bad hestitation so I took apart the carb and cleaned it, there was some crap but not too bad. The small o ring for the pilot ???? (forget what they call it, its only on the 25 hp carb) jet was split. I put it all back togeather and it idles really nice. When you drop the throttle for quick acceleration there is no problem, only when you go slowly up to wot. I thought maybe the transisition ports might be clogged, but they are not. It just falls on its face around 2,000rpm..... anyone know what the pilot jet does, is it an air jet or fuel? Any help would be awesome!
  #2
Old May 28th, 2007, 06:35 PM
Vlad D Impeller's Avatar
Vlad D Impeller Vlad D Impeller is offline
Default Re: 25 Mariner Carb issue
Is the vents on the fuel tank open during operation?
Are your fuel lines tight enough to prevent air leaking into the system?
  #3
Old May 29th, 2007, 12:44 AM
Thats a good point, I'll check that tomrrow, The plugs were running on the lean side, which could be due to an air leak, but I would think the hesitation would be all the time if there was an air leak.... interesting though, thank you. I'll look at it tomrrow.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Carb issue???????? sikz3 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 5 May 28th, 2007 08:56 PM
carb issue scott68 Johnson & Evinrude Outboards 6 August 9th, 2006 09:22 AM
Carb Issue cjflanagan Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 43 June 13th, 2006 06:43 PM
Carb issue or just break in issue jwronkow Johnson & Evinrude Outboards 10 May 6th, 2006 03:35 PM
95 Mariner, 25hp carb issue - need help bostie007 Mercury & Mariner Outboards 8 July 30th, 2005 05:06 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
