Alpha 1 Generation 1 Trim cylinder assembly
rjrjs
I have taken my trim cylinders apart to drill and tap the cylinder caps for magnesium anodes. Mine are the old style with no tapped holes in the caps. In attempting to reasseble the cylinders I noticed that I lost the setting for the spring tension on the piston valving. (the three balls that pop off if excessive reverse is applied or if the outdrive strikes something in foreward motion). Any ideas on inch dimensions for setting the springs?
