My review of past threads didn't yield an answer, so here goes. I don't know if all of this is relevant, but here it is. I bought the motor used with allegedly low hours about a year ago. I had a local repair shop tune up and test run the engine to confirm it was in good shape. It sat for a year with Stabil in the gas. I test ran it twice during that time using a water hose for cooling. It started and ran fine. About a week ago, I launched my boat and started the engine, running it at a low speed. After a few minutes the engine began to die, but would restart with the choke engaged. I noticed there was no water coming from the P-tube and the overheat warning sounded about the same time. I rowed the boat back to shore. A test run the following day revealed no water from the P-tube. I subsequently replaced the water pump assembly and the cooling system works fine now.
During test runs, the engine would run at speeds above idle, but die after several seconds at idle. It restarts immediately if I engage the choke for a second or so. I am running new gasoline and have tried two new fuel lines from two new gas tanks. I have rebuilt the fuel pump and replaced one cracked component. The problem continued. I removed, inspected and cleaned the carburetor. I did not change any adjustments on the carburetor. When I try to adjust the idle down using the trottle stop screw, it will die before the idle gets down to what sounds like a reasonable idle speed..
What do you suggest to diagnose and cure this problem?
