I posted a while ago on changing the carbs on a 140hp 1986, I installed the 1995 130 cabs and bodies and fit perfect. I left the jetting the same as the the new carbs. My question is I'm having trouble with a cold start, The solenoid works but I have to add more fuel with the box off to get it to start. After it starts it response to the choke till it warms up, after that just touch the key. Any idea's. Thanks for any thought in advance. It has Boyseen reeds, I did not richen the idle jets but it is not spitting back, I adjusted the idle screws for a smooth idle
