Power Trim leak? (milky overflowing trim fluid)
hal2814
I was finishing up winterization yesterday on my 1990 Merc 4.3L Alpha One when I noticed the power steering pump reservoir was overfolwing and the fluid was a milky white mess. The power trim still functions properly but I haven't touched it since I noticed the fluid since I don't want to damage anything. Is this some sort of leak? Is it something else? What sort of steps can I take to confirm the problem? I'm afraid of performing the leak testing I found in the Merc manual pdf with the fluid in that shape.
Don S
Re: Power Trim leak? (milky overflowing trim fluid)
Water is leaking in past the trim cylinder shaft seal, it's a double lipped seal, so it won't leak oil out, just water in. That is why it overfills itself.
Which Is It,..??.....
Steering or Trim,..??.....
Scaaty
Thats why I didn't answer it earlier. Leaky trim turned into Power Steering....backed off before a headache I couldn't get rid off showed up
Don S
Didn't notice that till you guys mentioned it. But my bet is that it is a trim problem. Milky oil in the power steering would be pink. The trim/tilt oil used in Mercs is SUPPOSED to have oil in it, which turns white, or gray. but not pink.
hal2814
Sorry, my mistake. It's certainly trim. Should've been "trim pump reservoir." Power steering is a-ok. Just a typo on my part.
hal2814
Power trim isn't something I've had to work with before so forgive me if this comes off as a dim question. By "trim cylinder shaft seal" do you mean the end cap (The part labelled "A" on figure 22133 on page 5D-3 of this doc http://www.boatfix.com/merc/Servmanl/6/6D5R3.PDF)? That seems to make the most sense based on Don's desription. And thank you guys so much for the help even if I did give a confusing description.
Don S
Yep, that's the one.
