2 Engines 1 starter battery?
Wrighty
I am just starting the electrical fit out on my yacht. There are 2 Yamaha outboards. Can anyone advise if these can be directly coupled to a single starter battery? I am then looking at a second battery for domestic use.
tommays
Re: 2 Engines 1 starter battery?
For the yamaha i would post over in the Yamaha Forum there are issues with outboards that require wireing in spec with yamaha guidelines
Tommays
Wrighty
ricksrster said:
Here is a link to Noco isolaters installation guides. You will find different set ups there.
http://www.noco.biz/installguide.htm
Had a look at the Noco site and it doesn't seem to cover 2 engines - 1 starter battery! The outboards are only 9.9hp each so I was trying to plan a simple installation using the domestic battery as starter back - up as well.
Cheers, Steve.
Silvertip
Honorary Supreme Mariner
As was mentioned, go over to the Yamaha forum and look at the two engine discussion between Rodbolt and myself. While this discussion involved bigger engines, there are some things you need to consider and Rodbolt is the guy you need to guide you.
--GQ--
Wrighty, the possibilities are endless. You need a diagram? What you got for starting mechanism; key or switch?
j_martin
The most likely point of failure is a dead battery. I would think for reliability reasons that you would want seperate systems, with a battery, starting loop, and charging loop for each engine.
The reason for multiple engines is redundancy, don't cheat on a $50 part.
hope it helps
John
