Re: Lower unit appears to be stuck in forward on my 90 HP FORCE
Robert, to me it sounds like you're not getting the shift shafts to connect assuming you don't have damaged gears...<br /><br />Let me tell you what happened to me when I was reattaching the LU on my 50hp Merc.<br /><br />I had a **** of a time getting the lower and upper shift shafts to line up... Here is why...<br />Everytime I tried to push the LU up and thought I had the shift shafts lined up... The upper shaft would be pushed upward, never really engaging with the lower shaft (it is splined also btw). So when I thought they were engaged they weren't... You can tell if the upper shaft has been pushed upward by looking at it under the powerhead where it attaches to the shift linkage. What I ended up having to do is put something on top of the shift linkage (a wedge or block of wood, whatever) to prevent it from moving upward so easily, if I didn't get the shafts lined up exactly. This way I could give a little more force on the lower unit and move the prop, jiggle the upper shaft, whatever it took to get the shafts to engage.<br />Obviously you want to make sure the shafts are in the same gear position. Normally you want both to be in forward when you do this... You can use a socket that fits over the lower shaft to switch gears. <br />I also had to use a small bent piece of metal to help me position the upper shaft in line with the lower, those dang things just wouldn't line up at all. But once I finally pushed the upper shaft over a little with my makeshift tool, I was then able to get them together without worrying about pushing the upper shaft upward....You'll want someone to help you, don't try to do this yourself or you'll have a nervous breakdown like I did...
