ianyoung77
- Mar 28, 2005
- 121
I have a 1990 50DETO Yamaha. According to my Clymer manual the charge coil resistance should be 368-532. I measure 190. Should I replace this coil? <br />The motor is running intermittently. I also found one of the ignition coils was high resistance so this may be the culprit, however, whilst I was looking I thought I should check everything. The other ignition coils and pulser coils were all within spec.<br />I also notice on other posts that there are additional voltage checks that can be done. My manual does not cover these at all and I can't get the original manual anymore. Should I do these checks?
