  #1
Old December 21st, 2005, 12:39 PM
flounderman flounderman is offline
Default 1989 115hp yamaha power head temp.
I replaced the thermo. on both heads and ran the motor for a bit. The port bank is about 125* and the starboard bank feels like a room temp beer. I use the motor in salt water and I bought it used. I did get it hot once, got into some kelp and the buzzer went off along with a cloud of ???. but restarted and it ran fine. I did a comp. test 119 _121 psi. Does any one have a comment or had a similar experience ?
  #2
Old December 21st, 2005, 01:13 PM
andy6374 andy6374 is offline
Default Re: 1989 115hp yamaha power head temp.
I'm sure almost everyone has gotten debris enlarged in the waterpick at some time. Sounds like you didn't hurt anything though given the compression readings.
  #3
Old December 21st, 2005, 02:12 PM
TxShorty TxShorty is offline
125 sounds a lot closer to right than room temp beer! Maybe there is some debris causing the cool side thermo to stay partially open.....
  #4
Old December 22nd, 2005, 07:04 AM
Both thermos. are new,I did not notice any "debris" but I did scrape away salt deposits. The new temps are about the same as prior to the thermo. change.
  #5
Old January 4th, 2006, 07:32 AM
thanks for the help guys I have tabled that project for another, the temps are liveable but I still dont understand why they are so different on the two heads.
  #6
Old January 4th, 2006, 08:28 AM
It can be a mystery. I know many times each bank on a V6 or V4 will exhibit different compressions. And it will run fine as long as the starboard bank's compression is even as well as the port bank, even if the starboard and port are not withing the 10% limit. Example:1,3,5~1152,4,6~100 or even 95
  #7
Old January 4th, 2006, 02:39 PM
Fjbango Fjbango is offline
just a contribution, may not be exactly what you are experinecing. I found an internal "hole" in the head cover gasket of my yamaha. One (at least) role of this gasket is to prevent the cooling water to flow except if the thermo is open. when this gasket is blown, the water is no longer controlled by the thermo, it runs through the hole and keep cooling this side of the engine regardless the thermo.This gasket has a metal core, i guess steel (not stainless) it was badly corroded and the high water pressure (contribution of a stucked- closed defective bypass valve) produced the hole.This is my theory from what I see now I am dismantling my engine ("see 1991 200 hp yamaha broken bolts nightmare") BUT I am pretty convinced that big temperature difference in an otherwise ok firing engine is due to big difference in cooling water flow.If it is working just let it be, dont risk to go through what I am going now!good luck and keep the posting going!Frank
  #8
Old January 5th, 2006, 07:49 AM
thanks guys, Fjbango I have been following your journey, buddy - - - if I were you I would hire someone to steal that thing. Leaving mine alone sounds good. If I ever meet GOD I will ask him to please make the 2nd commandent " THY SHALL NOT HAVE TO WORK ON ONES OUTBOARD".
  #9
Old January 5th, 2006, 08:54 AM
Canuck 16 Canuck 16 is offline
You sure the port bank is warmer than the starboard?Should be the other way around.Cheers... Canuck 16.
  #10
Old January 5th, 2006, 09:59 AM
Canuck 16, I am sure.
  #11
Old January 5th, 2006, 04:27 PM
Let us know what the outcome is.Good luck!
  #12
Old January 6th, 2006, 11:53 AM
On my 200hp V6, the starboard head is always warmer than the port side. The water enters the PH and flows thru the port side before going to the starb side, so the water is already pre-warmed before it enters the starb side of the motor.Maybe someone ( Ray, Rodbolt ) can tell us if the water flows differently in the V4's.
  #13
Old January 6th, 2006, 12:56 PM
B.autry4711A B.autry4711A is offline
Hello everyone, I am curious myself. I own a 1989 Evinrude SPL V-4 88 horsepower crossflow. What mine does is after I warm it up say 5 minutes at idle speed my heads get hot . I can hold my fingers on the heads for about 4 seconds before I have to remove them on both heads. Yes, I think the starboard bank is hotter than the port bank.
  #14
Old January 6th, 2006, 01:05 PM
Yep, sounds a little warm B.B! At idle speed I could hold my hand on either head all day.When was the last time your water pump was changed?
  #15
Old January 6th, 2006, 01:23 PM
Canuck 16, I changed my water pump out last year in March 2005. It pees a good solid stream out of the tale-tale, but cools down excessively when I rev it up somewhat, but not over 1,500 rpm's for fear of running away motor.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1989 Mecury 115 temp alarm and power sfeldt99 Mercury & Mariner Outboards 0 July 11th, 2005 06:15 AM
Yamaha 115 2-stroke 1989 Blown Head venajeff Non-Repair Outboard Discussions 1 January 19th, 2004 07:57 AM
yamaha power head won't turn gwm72 Yamaha & Suzuki Outboards 5 October 27th, 2003 03:49 PM
Traker 1989 70HP Pro Series 3rd power head! galentefrogman Johnson & Evinrude Outboards 2 September 23rd, 2003 03:14 PM
1979 Merc 115hp power head ? dmelton Mercury & Mariner Outboards 2 July 29th, 2003 06:23 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
