hello
take one aux leat to the house batt and the other to the starting batt for that aux lead engine. make sure the switch keeps the two engines seperated. need a minimum of two switches and I would prefer 3. wire the autobilge pump wire(fused of course) to the batt side of one of the switches. if everything is wired correctly when you leave for the day or have an electrical emergency/incedent all the power can be secured to everything. once switched to the off position the only thing "hot" should be the auto bilge switch.
