PLEASE HELP!! IGNITION PROB!!!
Laro
Hey folks,<br /><br />First time post for me here. <br /><br />I have a nice little old boat, 1977 20 ft Grady White in very good semi-restored shape. I LOVE THIS BOAT!<br /><br />The engine is a 1984 220 HP Yamaha. Now, I realize the engine might be a little tired, but everybody tells me to keep running it until it gives out. It NEVER does! Recently, I had it serviced and the shop guy told me there was no corrosion in the engine at all- Same thing with the drive unit. And the compression on the pistons is fine.<br /><br />So, here is my problem: When I try and start the engine, it fires up with no problem. But the second I let go the ignition key and it pops back the center position, the engine shuts off.<br /><br />Initially, I thought it was a bad key switch, so I changed it and put a brand new one on, same problem is occurring. So I went to the engine and by-passed the Microcomputer Ignition System box by reconnecting the plugs directly to each other. The engine cranked up like a charm and ran fine. The only problem is that the engine won't shut off with the key and I then have to unplug the bypass to shut it off.<br />Plus, I am assuming that there is some kind of benefit to having the Microcomputer Ignition operating normally, but the **** if I know what it is!<br /><br />Now, I had a mechanic remove the separate oil reservoire tank and automatic-mechanism a while back ago so I now mix my own fuel into the gas tank at 50:1 because it broke and was not worth it to fix on such an old engine.<br /><br />I don't think it is the microcomputer unit because I think that if that were the problem, the engine would simply not start at all. Right??<br /><br />A new ignition box for this engine is $1,300.00 and not worth it. <br /><br />Can anyone shed some know-how here?? Suggestions?? I know it is an older model, but I'll keep my fingers crossed hoping that you can help. You see, my wife and I have a 2-year old daughter. As you married guys know out there, $1,300.00 bucks ain't gonna cut it with the Mrs. for an old boat when you have a growing baby!<br /><br />PLEASE HELP!! I haven't fished in weeks and I am showing withdrawal systems!<br /><br />Alfred
steelespike
Re: PLEASE HELP!! IGNITION PROB!!!
Yaro, I cant for the life of me figure out what could turn off your key switch or how.<br /> NAPA has ser. manuals for your motor should have<br />wiring diagrams.<br /> Did you use proper switch for outboards?<br />Most outboards use an open circuit to run and a closed circuit to stop.Start run/stop switch should be easy to hook up with the help of a manual,if you want to by pass<br /> regular set up.
almost retired again
Hi Al,<br />Sure you can run it that way, but I wouldn't want to disconnect something back at the engine each time that I needed to shut it down. Not only would it be a hassel, but it is somewhat dangerious. I'll do some research and see if I can't help you solve your problem.<br />Hang tight
Laro
Thanks Almost,<br /><br />It sure would be a great help. I'll keep checking back here often until I get this thing figured out. <br /><br />Such a strange problem and it seems like it would be easy to figure out, right?<br /><br />Perhaps if I understood more about how a key switch works on this unit I could solve the problem. I may take the above advice and get myself a shop manual. I'm ripping my hair out on this cause it is so unusual <br /><br />Thanks again.<br /><br />Alfred<br />(Miami) :confused:
Reel Appeal
Laro,<br /> I'm not sure about your Yamaha,but some outboards require a KILL SWITCH HARNESS.If the harness is not attached to key switch(area) the motor will not run.(unless you push in?).Ask your dealer about this for a '84 Yamaha 220... :) <br />The harness is usually attached somewhere to the control box/shifter.Either that or look for a seperate(toggle?)switch on same....
Laro
Thanks Reel,<br /><br />I do have a kill switch, but I made sure the harness was in place. but you know, I did not replace the kill switch, only the key switch (which is right above). <br /><br />you've given me an idea- Could it be possible that the kill switch has gone bad and that even though the harness is in position the circuitry inside the switch itself could be in a permanent "EMERGENCY" kill position? Maybe a ground in there is messed up. I wonder. I'd have to change the kill switch to find out. <br /><br />But on the other hand now that I think about it, <br />I DID disconnect the kill switch all together as a test when I took the throttle unit apart and the problem persisted.<br /><br />Don't know what to do :rolleyes: <br /><br />Alfred
Laro
Hey Almost retired,<br /><br />Still having problems here. Let me know if you've talked to anyone.<br /><br />Goin nuts with this!! Already tried checking everything with a test light. No Luck.<br /><br />Alfred
