  #1
Old March 3rd, 2004, 09:57 PM
rdaystrom rdaystrom is offline
Default Yamaha 50 hp, oil slung off flywheel ??
Hello, My brother purchased a used boat with a Yamaha 50 hp 2 stroke engine, mix type. (not oil injected). Sorry, don't have model number right now. Upon removing the engine cover I noticed where some oil had sprayed or slung out from the flywheel and got on the inside of the cover as well as generally coated the engine itself with some even on the pulse or pickup coil. Does this indicate a leaky crank seal? Do these seals normally leak or pop out? Is it replaceable without splitting the engine cases? Also is there another source of oil.? Any help or advice would be appreciated. Thanks, Robert
  #2
Old March 4th, 2004, 01:20 AM
rodbolt rodbolt is offline
Default Re: Yamaha 50 hp, oil slung off flywheel ??
hello if it runs ok I would not sweat it. if it does not cough or stall at an idle then no worries. how old is the motor? are you sure it came from the flywheel and was not drawn to it? are you sure its not something like fluid film that was sprayed on? but mostly 2 strokes dont stay clean and shiney for their entire lives. clean it of and keep watching it. but no there is no removal and installation tools for replacing the seal with it still in the block. its rare to see that type of failure. good luck and keep posting.
  #3
Old March 4th, 2004, 02:53 AM
lakensea lakensea is offline
If, in fact you are losing fuel/oil mixture from the top seal, you are losing crankcase pressure which will cause the engine to run lean. You also are losing lubrication to the top bearing. You do not have to split the case to change the seal. First thing, get a service manual for that engine. You will need a proper flywheel remover and slide hammer type seal remover (the type with a self-tapping screw in the end. Remove the flywheel, stator & trigger assembly. Then carefully drill 2 holes in the seal. Screw the slide hammer into each hole alternately and pull seal out. Using a large socket or similar item, tap the new seal in.
  #4
Old March 4th, 2004, 03:03 AM
Thanks for the encouraging response. I hope it is something minor like you said. Unfortunately we didn't get to really test the engine so we will find out about the running qualities soon. By the way, the starter was real loose?? Makes ya wonder?? Maybe it just loosened from vibration but I also suspected it was "left" loose by a mechanic but who knows? No evidence that it has been wrenched on otherwise. I tightened the starter bolts up. Oh well, everything looks great otherwise and I'm hoping it runs good. Enough speculation, will test it and we will let you know how it goes. Thanks again, Robert
  #5
Old March 4th, 2004, 03:08 AM
lakensea , Thank you as well. Sounds like the seal is almost identical to the Yamaha motorcycle crank seals I replaced many moons ago. I will clean the engine off and run it some and recheck for oil. I am aware that if it is lean because of a seal it could hole a piston so I will be very cautious on test runs. I may just pull the flywheel anyway to be sure. Gotta come up with a puller first. Thanks again, Robert
  #6
Old March 6th, 2004, 07:07 PM
Before I could take a look at the engine again the boat was taken to a shop. They ran the engine and said it was ok and totally disregarded my blown crank seal theory. This morning I went along with my brother to the lake where we ran it and it did fairly well but idled a little rougher than I thought it should. I went home and my brother fished for several hours and then returned home. He checked the engine cover and new fresh oil had slung onto the engine cover and all parts around the flywheel were oil coated. That was more than I could stand so we bought a puller and removed the flywheel. Sure enough the crank seal was bad. The outer body of the crank seal was there but the entire seal lip center part was gone. I'm just glad it didn't burn a hole in a piston on our test drive. I plan to get the seal and replace it.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
yamaha 9.9 4-stroke flywheel joblo33 Yamaha & Suzuki Outboards 1 April 10th, 2005 12:34 PM
91 200 yamaha outboard flywheel cannot be turned manuelly Rock River Girl Yamaha & Suzuki Outboards 1 August 30th, 2003 06:37 AM
86 yamaha 70hp flywheel stuck nedmina Yamaha & Suzuki Outboards 1 August 9th, 2003 04:19 PM
Flywheel Removal on a Yamaha 2hp - Need Help Mathew15 Yamaha & Suzuki Outboards 1 April 1st, 2003 01:07 PM
Frozen flywheel 25 yamaha or not? aussiefisho Yamaha & Suzuki Outboards 3 January 7th, 2003 04:21 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
